christo829
Voymom said:So you are saying that it would be surprising for it to be stuck open when the engine is cool? You speak Yoda-ish lmao and I have a hard time deciphering your language when on 10 types of pain killers![]()
So, it doesn't need to open until the engine warms up? Which would explain why it was closed when the hubby took it out? I tried going all day without any meds...but the pain kicked in after getting the hiccups![]()
Saying it is "stuck open" is kind of a convenient label, but isn't perfectly descriptive. Some will break, and will actually be open even when really cold.
Most just get weak, so they begin to open well before the appropriate operating temperature is reached. Once they cool off,
they'll close up again.
The engine could be at 100 degrees, and the thermostat would be closed, then start to open at 120, instead of 190. Once it cools
back down below 100 again, it would close back up, and look like it was OK.
Just be glad these aren't like the older thermostats that could just as easily fail and stay closed, resulting in fun things
like blown hoses, warped heads and seized engines...
Cheers-
Chris
