Can I Swap my 2003 Ltz bumper with the 06 LT?
fadyasha
1,134
Hey folks :p
Been debating this a while now and planning on swapping my rear 03 Ltz bumper (basically the LS bumper) with the new model LT.
I remember reading its a direct fit on the old os but wanna be sure.
Any ideas?
I can't find the thread, but the brackets aren't the same so you'll need those also. There's a thread on the OS about someone swapping to a LT bumper and a SS grille with the part #s
so bumper and brackets. Good to know :biggrin:
Edit:ok after some more search and digging think this is what I need Spacer support between the welded beam and bumper, the bottom brackets and correct plastic push rivets, & step pad.
I am going to be putting the 06+ bumper on mine in about three and a half weeks. I'm getting a new impact bar/reinforcement, the secondary reinforcement plate and the screws to hold it on, step pad, and some new plastic push pins for the bottom. I can't forget the paint either, it's coming charcoal grey. I can't imagine it being anything other than a direct fit once the steel step is put in.
Nice! Think the install process would make a great article :) you should consider that lol!
Now that I know what I need it's time to start doing my math! Thanks
I totally missed that you said REAR in the OP
Thats OK... are you wanting the helmet?
It was early and I hadn't had coffee, no helmet needed yet.
lsx.trent
