Getting a P0340 I figured replacing the old original CPS was a good idea. However the same code continued with the new sensor.
So I tested the old sensor and found that the output latched when activated. Is that the way it's supposed to work? I have battery voltage at the connector, so that appears normal.
The new sensor output was less than 5 volts, so it has a problem. And it also exhibits the latching behavior, so I'm thinking that its normal.
Interestingly enough, it starts just fine with the CPS disconnected. Even the SES light goes out.
