Bumper sagging
Front or rear?
Corners or middle?
We gotta train you better how to describe a problem. :biggrin:
Front corners are held up by a slotted thingie glued to the bumper cover that goes over a metal mushroom thingie on the edge of the fender sheet metal. See if that's it.
If not, you typically take the bumper cover off using the screws and plastic pins cleverly hidden around it, and then see what's broken/bent/ripped off.
warriorpluto
215
Front or rear?
Corners or middle?
Oh on the drivers side on the corner by turn signal. You see the gap?
warriorpluto
215
Yep, it's the slotted thingie. Jumped off the mushroom or the plastic tore off the back of the bumper cover. Take it off and repair, or remove the wheel well lining and look from inside.
Oh on thanks I'll take a look at it but what if it needs to be replaced.how much does the plastic piece usually run?
warriorpluto
215
Aftermarket $350 primered and then you have to pay who knows how much to get it painted. $750+ for OEM. Plus installation if you don't DIY.
If the clips beak I have to get a new bumper?
I took mine off and threw it away, so I've never had to repair one. I've read there are epoxies that may work through the immense temperature extremes involved. No personal experience. YMMV. Consult a professional.
warriorpluto
215
I'll see how bad it is. Any good aftermarket bumpers that are a different design? Cosmetic wise?
Yasha
