- May 21, 2013
- 41
Hello everyone, I recently made the transition from T.V. to here and I was looking around this forum to see if I can pin point what’s going on with my Tb. I just recently installed Driver/Passenger inner/outer tie rods, sway bar links, new DG rotors and DG brake pads. This was all done by me. I made all these changes since I felt a bad vibration when applying the brake but I only felt the vibration on the passenger side. Since replacing everyting mentioned above it still does the vibration when applying the brake at high speed. Also the TB starts to vibrate only from the passenger side when I go anything above 60.
I almost forgot both upper and lower ball joint were replaced by Pepboys a year ago. The only thing I can think of that might be causing this problem is the struts since they are about 3yrs old.
Can anyone give me there two cents on what might be wrong? Thank you in advance for any info.
Also whant to Thank You guys from the old forum( T.V.) you guys helped me do everything mentioned above.
