so today i was going around 65 on the highway just cruising when all of a sudden i felt like a pop or like i ran over something. i pulled over and my abs/brake lights came on and my dash said inspect brake system or something like that. once i stopped the car i could not drive fwd. the engine would move like if the car was braked. i popped it on reverse and it went back about 6 ft before stopping like it hit a wall. i then put it on fwd and it went up like 6 ft and then stopped like if it hit a wall. at this time i had already called a tow truck. i needed to know the mile marker so i had to drive up (8degree weather today without the windchill). i let it cruise on drive and slightly applied the accelerator and the car went ahead with no problem. i never accelerated more than 5mph. once i got to the marker i stopped and turned the car off. the flat bed showed up and popped the car on top. once we got to the shop he let it down. turned the car on once it was down and went to park it on the sidewalk and all i heard was clunking fwd or reverse. it didnt move. had to move it on neutral. didnt see anything underneath the car to indicate fluid until i was picked up...GREASE UNDER THE DIFFERENTIAL!
about a month ago i had the car go to the shop for a loose transmission hose and he reminded me (from summer time) that the SEAL for the Differential Drive Pinion Shaft Bearing needed to be changed since it was spraying grear up into the top of the differential. he had to fill up the differential with grease.
now that i told u my story, is it a blown differential?
if it is, im going to go ahead and probably get rid of it. i cant keep fixing the little things that keep breaking on this. ive put way to much money into it already. its an 02 so i know it needs maintenance, but ive changed the whole frontend (suspension) and just cant keep going.
