I'm astonished. A 2006 TSB for afterblow.Simon01 said:I knew I wasn't imagining this!
Thanks! Sounds like you have to ask for it to get installed. Not sure this was a software update applied at the factory to all vehicles. the roadie said:I'm astonished. A 2006 TSB for afterblow.Thanks! Sounds like you have to ask for it to get installed. Not sure this was a software update applied at the factory to all vehicles.
Just to be clear - it says this new function doesn't leave the blower running immediately after you turn off the key. It says that 10 minutes AFTER you turn off the key, it comes back on for 10 minutes at 30% power under certain conditions.
If the blower stays running immediately after you turn off the key, I think it's still the speed control module. A good experiment is to try to get the blower to stay on, then leave the ignition alone and see if it quits after 10-20 minutes. If not, then cycle the ignition on and off again to try to get it to quit. Or see if you can get it to run at ignition off time, at full power, and see if it stays running at full power, or throttles back to the 30% mentioned in the TSB.
#05-01-39-002A: Musty Odor from HVAC System (Reprogram HVAC Control Module to Enable Afterblow Function) - (Mar 17, 2006)
Subject: Musty Odor from HVAC System (Reprogram HVAC Control Module to Enable Afterblow Function)
Models: 2004–2006 Buick Rainier
2003–2006 Chevrolet TrailBlazer, TrailBlazer EXT
2003–2006 GMC Envoy, Envoy XL
2004–2005 GMC Envoy XUV
2003–2004 Oldsmobile Bravada
with Automatic Temperature Control HVAC System (RPO CJ2)
This bulletin is being revised to add the 2006 model year and update the calibration release date. Please discard Corporate Bulletin Number 05-01-39-002 (Section 01— HVAC).
Condition
Some customers may comment on a musty odor from the Heating, Ventilation and Air Conditioning (HVAC) system. This condition occurs most often on initial start up after the vehicle was driven on a hot humid day.
Cause
This condition may be caused by condensate build-up on the evaporator core, which does not evaporate by itself in high humidity conditions.
Correction
Important: The afterblow function should not be enabled until after the purpose and operation of it is explained to your customer and they approve of the change. Once the afterblow function is enabled there are no calibrations currently released to disable it.
Technicians are to reprogram the HVAC Control Module with an updated software calibration that will enable the afterblow function. The new calibration will be released beginning with TIS satellite data update version 2.0, which was made available February 5, 2006. The blower motor will turn on approximately 10 minutes after the vehicle is shut off. The blower motor will run continuously for 10 minutes at a 30% duty cycle. The afterblow function will only activate if the air conditioning compressor was engaged during conditions of high ambient temperature. If the vehicle is started within 10 minutes of the last key off, the afterblow function from the previous key cycle will be cancelled.
Technicians should not attempt to reprogram a vehicle with a Manual Temperature Control HVAC system (RPO CJ3).
Technicians should perform this HVAC Control Module reprogram instead of installing the Electronic Evaporator Dryer Module Kit referred to in the Air Conditioning Odor bulletin, Corporate Bulletin Number 99-01-39-004A .
Simon01 said:I just pulled it from SI. Any dealer should be able to do the same.QUOTE]
OK, what is SI? Thanks.
DAS said:OK, what is SI? Thanks.
