- Dec 5, 2011
- 77
So I installed the drop struts this past Saturday. I already have the belltech 2" lowering spring in the front. Tony told me to put 2 16mm on each side. Drove around. Didn't like it.. It's not stiff or absorbs the bumps good enough. Tony told me i need to put the stock OEM spring in the front. So I ordered them from Rockauto. Ill be getting them this Saturday. But now I'm getting a vibration/ Thud, thud, thud on my drivers side now. I feel it in the gas pedal and steering wheel also. The thud noise Comes and goes. When i go over slight bumps feel it a lil. But definitely when I'm making right turns. I know i tightened and double checked that all bolts were tight when putting the struts. I wonder if its that drivers side axle as the inner boot cracked (has a slight in the rubber) 2 months ago and grease has gone everywhere? I cleaned it up on saturday man was it a lot go grease. Or can it be the inner inboard axle bearing? It can't be my stabilizer bar end like cause i checked those to be sure they were tight. Or can it be i have a bad strut?
