Bad Alternator
cxkali
would it be possible for a bad alternator to cause the reduced engine power light to come on as of right now mine is only putting about 70amps have a thermal clutch fan with the code p1515 and I think it was a p1221.
sorry put this in the wrong section.
the p1515 code asks if you have a p1221 if so diag that first.
P1221 runs if battery volts is above 5.5 volts so I dont think the alternator could cause it because if your battery volts are that low the truck is not running( not enough power to run the fuel pump or fire the coils)!
There are a few bullitins to check your 5v ref lines because one could be pulled low and setting codes.
Other than that these code are for a disagreement between throttle position sensors 1&2. So it could be an internal fault of the throttle body, But make sure your 5v reference voltage to the sensor is good first.
When I had my bad alternator, I didn't have any codes or REP. What I did have is that red battery light on and my DIC telling me that my battery was not charging. I wish I could help more...
Mrphoepnix is on the right track. This is a common issue and it seems like it comes up every few weeks or so.
Basically what you have is a short in the 5 volt reference wiring. This 5 volt circuit is common to both the throttle body position sensor and the fan clutch. Hense the reason for the two codes.
You will more than likely find exposed wires, (right before it enters the fan clutch assy) which have been rubbing against the plastic mount. This has been documented as an issue with some fan clutches, that the protective sleeving for the wires does not extend far enough to protect it from this rubbing.
Replace/repair the harness to fix.
i changed my clutch fan to a newer 08 model so i know its not the clutch fan so im not sure what it could be. i may need a new throttle body after all.
Where are the wires that used to go to the fan clutch?
ive got it wrapped in tape and taped it to the battery holder bar.
Sexyscissors
