Any way to tighten loose center caps?
400Magnum
49
I know the obvious answer is to just buy new ones, but I don't want to spend that kind of money on something that's just going to end up loose too. Is there anything that I can do to modify the center caps to keep them from being so loose that they rattle around when driving slow? I figure if they're that loose they're going to fall off when I hit a bump or something one of these days, and they just sound bad driving around at slow speeds.
Any thoughts?
jham
1,334
First thing that come to mind is a piece of metal that will push the tabs on the center out to hold it in place. But there's not alot of material to attach it to.
AtlWrk
674
If the Envoy caps are similar to the TB caps:
You could try CAREFULLY heating the tabs near the base and gently coaxing them a little farther out.
Or slip some large diamater heat shrink over one or more tabs?
Wooluf1952
2,663
Milwaukee, Wisconsin
I was going to suggest wrapping some electrical tape, but I like the shrink tubing idea better. :thumbsup:
Harbor Freight has the tubing pretty cheap.
Just be careful, when shrinking the tubing, that you don't melt the cap.
Hatchet
2,405
Its been a long time since i had my stockers on. But mine were loose to. I fixed it, i forgot what i did to the caps tho. I need a pic of one. I think i bent the tabs back some or tightened them up or something. I forget, and i dont know where my stockers are at to look at them.
Mark20
1,630
You should be able to bend the tabs out a bit. You shouldn't have to go overboard doing it.
400Magnum
49
Thanks for the ideas guys! My first thought was just superglue some thin rubber to the outside of the tabs, but I like the idea of the shrink tubing better. Maybe do a combination of bending the tabs just a little and the shrink tubing. I'll give them a look to see what I can do.
Thanks again. I really appreciate it.
jmlock
4
I will say that your method does work for the plastic tabs that go over the screws on the drivers side kick panel. :biggrin:
kardain
557
when in doubt, jb weld the cap on.... Won't be loose anymore :raspberry:
Ayad
