where they using the cheap Mevotechs or the Supreme Mevotechs?HARDTRAILZ said:Members on ORTB had the balljoints go to junk in a quickness w mevotech. Like couple months quick
I actually agree, my Firebird is all Moog Problem solvers up front and Founders Performance rear parts (3-piece poly control arms and poly/poly panhard), but ChrisFix says he sees these Mevotech parts last just as long as Moog parts, we will see. It's a street truck where the closest to off-roading it will do is climbing the crappy driveway or some light georgia snow and I don't drive it all that aggressively anyway (gotta try to get decent MPG), I was just weighing the parts cost to mileage on the truck and opted to save some cash, the ball joints can always get replaced later if there is an issue when I get some cash saved back up, I was stretching myself thinner then I wanted to after getting the Belltech lowering kit (which sparked this whole fix any issue in the front end before alignment thing), so between the Belltech and the modified upper arms I had to go a bit cheaper then I normally like on the ball joints, but the truck has high enough mileage I wanted to replace the bushings in the lower control arm too, so I opted to do the whole arm.Paul Bell said:I've always believed Moog to be a better brand than Mevotech.
Most brands have two levels, the economy replacement and the "professional grade" part with the grease fitting, look at how Rockauto has an economy subsection and a daily driver subsection under ball joints for these trucks.Sparky said:I did not know there were two grades of Mevotech.
Side note, I have the same Founders LCAs and panhard on my Camaro.
The Moog replacement arm is what Paul Bell has pictured in the first post, as you can see there is no grease fitting in the ball joint. It is a Moog R-series part not a Problem Solver part, the R-series from the info I can find don't have the grease fittings.Tiggerr said:From what I've seen the Moog, mevotech, beck arnley, and even the delco all have grease fittings on replacement ball joints, tie rods, and LCA assemblies.
HUH. I didn't know Moog had a better version, it's not listed at rockauto, where I got the arms from. I trust the better ones have the cheaper ball joints but still the good bushings.Daniel644 said:The Moog replacement arm is what Paul Bell has pictured in the first post, as you can see there is no grease fitting in the ball joint. It is a Moog R-series part not a Problem Solver part, the R-series from the info I can find don't have the grease fittings.
I couldn't find the complete Moog arms in anything but the R-series, to get the better Ball joints (Problem Solver series) you have to press out and press in one of those and install the separately purchase problem solver ball joints, which was the whole reason I decided to give Mevotech a try (Rockauto actually had both the standard and Supreme versions of the Mevotech arms) so I got something with greasable ball joints, I don't think there is much of a difference in the Moog bushings either way.Paul Bell said:HUH. I didn't know Moog had a better version, it's not listed at rockauto, where I got the arms from. I trust the better ones have the cheaper ball joints but still the good bushings.
And THAT ^ led me to THIS> http://forums.offroadtb.com/viewforum.php?f=26HARDTRAILZ said:Members on ORTB had the balljoints go to junk in a quickness w mevotech. Like couple months quick
