antenna cap
If your out on the fringes of reception, you'll find it will be worse with the shorter antenna. Just less area to grab a radio signal. If you in a major metropolitan area you'll probably not notice a difference since you'll have plenty of signal strength.
Or you can get a nut and 2 washers that fit the antenna stud and some wire. Clamp one end of the wire (stripped) between the washers and hide the wire in the engine compartment.
oelarse
