Well, today I was tackling a loss of 2mpg, which coincidentally happened at the same time I put in my tuned PCM. After two tanks, I went from 17mpg avg. to 15mpg avg. Hooked up the Tech 2 to check things out. I did a code check and got a p0300 (random misfire) but it didn't set the CEL. Hmmm. So I swapped the other stock PCM back in and still getting the misfires. Went to misfire counts and I was getting the odd few misfire on cyl. 4. Not a lot, maybe one every 5 cycles or so.
So figured I'd start with the usual diagnostic step of swapping the coils. (4<>2). Misfires stayed at no.4. Swapped the tuned PCM back. Same deal.
Engine was hot so I didn't want to chance pulling the plugs and tonight I'm working. Figured I'd just throw in some new plugs anyway so I ordered a set from eBay (great deal). When I swap them out, I'll probably do a compression test at the same time.
So just to recap:
- PCM not at fault
- coil not at fault
Next steps will be:
- do compression test
- replace spark plugs (ACDelco 41-103)
So just to recap:
- PCM not at fault
- coil not at fault
Next steps will be:
