Ok so basically I am looking at installing a nexus 7 into my TB and I plan on going all out!
My current list consist of
-Joycon EX Steering Wheel Control PC Interface
Link
-FiiO E10 USB DAC Headphone Amplifier
Link
-A new amp and speakers to replace my factory bose
Amp
Speakers
-64GB flash drive for all my music
So basically where I am stuck is at the module for the door chimes/on star. I have the bose system but will not be using that anymore after this install since I'm going to run all the door speakers off my aftermarket amp with the original wires from the bose amp that run into the doors(maybe upgrade the wire). So that leaves me not sure what to do/ what to buy for door chimes.
The FiiO E10 will plug into the tablet and then run rca wires to the amp so basically I'm not using the stock head unit wiring harness.
I was looking at the CRUX SOCGM-17 GM Factory Integration Interface and was reading the wiring diagram and found this
FRONT audio inputs:
Gray for right side / White for Left side
REAR audio inputs:
Purple for right side / Green for left side
Wires with a “Black” trace go to Negative (-) side of speaker
and solid colors goes to Positive (+) side of speaker output
from head unit.
So does this mean I can just tap these wires into my speaker wires coming out of my amp that way I can still have my door chimes?
I don't have/use onstar so if that doesn't work no biggie.
Yes I know this is technically necessary but I like making my mods look/feel factory.
Thanks for the help! If you have any suggestions let me know.
Link
Link
Amp
Speakers
FRONT audio inputs:
REAR audio inputs:
from head unit.
