I have searched and sought advice from similar threads but my problem is a bit different and persists, so I am starting my own thread....
All lights on my 05 TB LS "flash" intermittently. This first happened a month ago. I have since replaced my battery. I have not noticed any "flashing/flickering" since replacing it until today.
I turned on the volt meter on my radar detector when I noticed it this morning. Normal running voltage registered at 14.2/14.3 (the numbers probably aren't accurate but the important part is what follows)..when the flickering starts, the volt meter shows a SURGE to 15.8/15.9 volts and then a drop to 12.5/12.6 volts. This surge/drop happens about 7 or 8 times over 20-30 seconds and the volts return back to normal for 5-10 minutes.
This affects headlights, tail lights, interior lights, dash lights, radio lights. It does not affect blinkers or hazards. The surging does not happen at idle, seems to kick up around 1000 RPMs and up. Nothing I do seems to make it worse or better(i.e. turning off radio, blower fan, headlights, turning on the AC, all interior lights, hi-beams). Load on the electrical system doesnt seem to be a factor.
Performance is not affected either, idle, power, RPMs do not feel different during the surging episodes.
Is there a single relay that controls all these lights?
