Got a few codes try to erase but couldn’t, car was in a crash driver fender snd smashed radiator core support, didn’t deploy bags, checked pretensioner for ohms, getting 2.4 on both, same with plug from pretensioner to plug under seat. Need help
I used a toothpick to push away the shorting bars, if you don’t you will get open or Infinity readings, with the shorting bar out of the way I get 2.4 ohms which is good, meaning the connector and the actual pre tensioner in the seat are good. I checked directly on pins of pretensioner in the seat and with the connector attached.How did you do the resistance checks?
I must confess until a few moments ago I had never read up on the purpose of "shorting bars" and what they were for and how they worked. I read just enough here at this link to give me a very basic understanding that might be useful if I ever have to check these circuits.
Tips and techniques for supplemental restraint system service
Let’s discuss the issue of fixing a vehicle that develops a problem and illuminates the SRS warning light, but has not been in an accident.www.vehicleservicepros.com
I do get infinity on plug that goes under the carpet to the module, so maybe a break in the wiring there, but not sure. I’m getting to the module as we speakI used a toothpick to push away the shorting bars, if you don’t you will get open or Infinity readings, with the shorting bar out of the way I get 2.4 ohms which is good, meaning the connector and the actual pre tensioner in the seat are good. I checked directly on pins of pretensioner in the seat and with the connector attached.
