Air Compressor
cxkali
Noticed the envoy is sitting lower then normal the compressor is not kicking on and wondering what would cause it not to come on so i hit the button to see if it was working and nothing happens. what should i inspect to fix the problem
First place is fuse box, second would be under the car to check wiring and the arm that is connected to the switch that senses the vehicle level.....these are connected to the rear end housing.
GMC Jimmy custom
