Amazon Product ACDelco - GM OEM Ignition Tumbler & Key Set... $33.00
6,830
As prompted by a mention in a recent Post by @Blckshdw ...Here are Seven Good Reasons for getting THIS ACDelco OEM Tumbler & Key Set:
(1) You've been nursing along a Worn Out Ignition Key ...and having very Sketchy Engine Starts.
(2) You've Lost or Broken the ONLY Ignition Key available for your TB-Envoy-Ranier.
(3) The Apocalypse Drops in... And you want to try to Start a Disabled or Abandoned Trailblazer.
(4) The Apocalypse Drops in ... And your "Crazy X" has had your Ignition Tumbler Changed out.
(5) Your out in the Salvage Yard with a 12 Volt Battery and want to test out some Electrical Parts.
(6) It NEVER hurts to have an Extra Ignition Switch AND the New Tumbler & Keys to make it work.
(7) You may NEVER get the chance to have one of these when you Really NEED it for an Old SUV.
https://www.amazon.com/dp/B002E572IC/ref=au_as_r?_encoding=UTF8&Make=Chevrolet|47&Model=Trailblazer|489&Year=2002|2002&ie=UTF8&newVehicle=1&vehicleId=1&vehicleType=automotive
Having this Complete Tumbler & Key Set avoids having to go though THIS PITA (and Expensive) Process with a Locksmith:
Keep the Old Tumbler if you decide to take it to a Locksmith or a GM Dealership with your Vehicle Title as Proof of Ownership so the Key Numbers can be obtained off of the Barrel of the Tumbler and a New Set of Keys & New Tumbler can be created:
mykrid
