AC compressor cycles on for no reason ( I think)
steveO
91
With the outside temp nowhere near needing A/C (40 DEGREES and same when even lower)
With cabin temp set to 70 degrees, the compressor cycles on and off for a period of time.
This cant be normal? What would cause this to happen?
This is normal. The AC cycles a little to reduce the humidity in the cabin and help defrost the windows.
steveO
91
I didnt have the defrost mode set, just using the climate control system.
I can say I dont recall this as happening before but maybe I never really noticed it till now.
If this is normal then I guess I have nothing to be concerned with.
Thanks
Agreed. You can force it off with the snowflake button, but not if you're in RECIRC or DEFROST mode, where the controller will override and cycle the compressor for dehumidification.
Yasha
