Hello all. I have a 2005 Trailblazer LS and it looks like I may have a leak on the AC pressure switch on the accumulator? I found a yellow oil that appears to be coming from the sensor. I did take a look at an older post from 2013 by forum member Hatchet showing a replacement procedure of the sensor that looks pretty straight forward. Most likely the o ring in the sensor has gotten old perhaps? AC is blowing cold. I should probably get a refrigerant check. Never had an AC work done yet on the car.
Here is the post from Hatchet:
gmtnation.com
How to replace the low pressure switch for AC
ok here is a how to find and change the switch on the accumulator... 1. Go out and buy the part, Pressure cycling switch. autozone cost 12.99 part#MT0968 2. Same as anything else, disconnect the negative on the battery... 3. Locate the part we are changing. It is Between the windshield...
