This is similar to the thread by blazinlow89 , but i may have a little more complexity. A month or so ago I began to hear what I thought was worn bearings in the front driver side hub. I've read that when you start hearing your bearings that it is ok to drive them a little longer, so I did not service them. Today I was towing a trailer with a four wheeler on it and the "rubbing" noise became a light grinding noise. about 25 miles more and the noise became more prominent and seemed to get worse.
Another 5 miles and the ABS light came on. When I started to pulled off the side of the road the ABS light went off the moment I touched the brakes and instantly the ABS kicked in and I could feel the ABS, even though I was barely touching the brakes at this point. They continued the anti-locking until I came to a complete stop. I started again, and the ABS light came back on. I tried the brakes to see if the brakes were still "anti-locking", but they were not.
Now that I'm back to the house, I'm going to jack up the front drivers side and spin the wheel and take a closer look.
Any suggestions for what it might be or what to look for?
Thanks
EDIT: My vehicle is a 2004 Isuzu Ascender 4WD about 106,000 miles I6
I checked the Wheel, there is some friction when spinning it, but there is lateral lay in the wheel, I checked the lugs and they are tight.
Thanks
