A/c not working
fredhouse
37
Hello every one,my name is Eric and this is my first post on the site and look forward to many more.
My a/c is not working,hot air blows out but compressor does not kick on.I have checked the fuses and i have tried to jump the compressor with a paper clip but that did not work either. I'm not sure where to look next,i have looked at many of the threads on the old site but can not find a schematic of the a/c system.Any help with this would be great thank you Eric.2003 trailblazer lt ext 5.3L.Also i have checked the pressure on the high and low side and they were equal at 98psi.
Welcome! This is certainly where the active support community is.
Here's the schematic. Could be the relay or clutch or the high side sensor. A high end scan tool could talk to the PCM and see if it's commanding the clutch to go on or not. Or probe the relay.
fredhouse
37
compressor is bad,i have a warranty so it should be covered.Thank you for your help i now know where all the parts of the a/c are.
moscoreli
