- Mar 18, 2014
- 34
I have a 2003 Envoy SLT. I replaced the A/C compressor when the factory one ground itself to death.
I have a evacuation pump that hooks to my compressor that has worked in the past.
I replaced the Dryer/Accumulator and the Orifice tube. The accumulator and the lines from the compressor will freeze over. Lots of ice will build up unless we manually turn off the air at times. I read this can be a plugged orifice tube. I took it apart again and it was plugged with debris. I flushed the system again and recharged it and it still does it.
The evacuation pump does not sound like it used to. Sounds more like the air from the compressor is going right through it. Doesnt have that suction sound it used it. Would the system freeze over like that if the system is not vacuumed properly? I'm wondering if the pump is working at all anymore.
Thoughts?
Thoughts?
