Hi all,
New to the forum and only recently purchased a 9-7x. I have been getting a lot of great information by reading old threads, but, now cannot find what I need and am hoping someone can help. Yesterday, I installed a new thermostat. (hands are healing well!) I purchased an ECT sensor to replace it as well based on the forums advice. The problem is that there was no sensor in the normal location. The block is not even tapped at that location. I also could not see it anywhere within easy view of that side of the engine. Given, I had a limited window to get it back together and felt the 172 degree running temperature(by scan tool) was a result of a stuck open thermostat, I put everything back. Yes, problem solved. Running 195 to 201 by scan tool, but, where the heck is the ECT sensor located on this version?
Thanks,
John
Thanks,
John
