Amazon Product 7 Piece Specialty Sensor Deep Socket Set for $30.00
8,561
If you have invested in any AES Wide Band O2 Sensor Gear for Non-OEM Tuned Engines and find the need to replace it without damaging the Expensive BOSCH OEM WB O2 Sensor... having THIS Kit for any such R&R will pay dividends.
Imagine getting 7 Sensor Tool Options in a Complete Specialty Socket Set... for Just Under $30.00. And Imagine EVERY Other Unique Sensor Under The Hood and on the Transmission (Input Shaft Speed Sensor) that are DIFFICULT to Access ..and R&R and Consider the Value here:
WYNNsky Oxygen Sensor Remover Set, Oxygen Sensor & Oil Pressure Sending Unit Master Sensor Socket Set, 7 Pieces O2 Sensor Socket Set
71z24UAQ+wS._AC_SL1500_.jpg715ynX4826S._AC_SL1500_.jpg71y08W+tbyS._AC_SL1500_.jpg71Qf3j-lUKS._AC_SL1500_.jpg71aWKklw42S._AC_SL1500_.jpg613N8qZur0S._AC_SL1500_.jpg
8,561
This remarkably HEAVY WYNNSky Model # TH1078 Oxygen Sensor R&R Kit arrived this evening.
The Notable artifacts are:
(1) Very Heavy and High Grade Steel. The Small Kit Weighs 4 Lbs 11 Ounces.
(2) Very Heavy Phosphor (Parkerized) Anti-Rust Treatment (Almost "Sugar-Frosted")
(3) Very NICE Blow Molded Case that locks properly and STANDS UP on its end.
(4) A COMPLETE O2 Sensor R&R (7) Part Tool Set that will work for OTHER Odd Sensors.
(5) ALL OF THIS ...for Right at Thirty Bucks!
A Chrome-Vanadium Steel Tool Set ...Courtesy... Amazon:
Here are the Un-Boxing Images.
OXYGENSENSORTOOLSET0.jpgOXYGENSENSORTOOLSET1.jpgOXYGENSENSORTOOLSET2.jpgOXYGENSENSORTOOLSET3.jpgOXYGENSENSORTOOLSET4.jpgOXYGENSENSORTOOLSET5.jpg
Alexaxl46
