Well, I did it this time. Before I took it apart, I knew the axle disconnect had a broken shift fork. The good news is, that was correct (thank you all here). The bad news is when I was removing it, it was stuck so bad I broke it.
As far a breaks go, this one is beautiful. When I first tried to get it off with gentle hammering and it was a no go, I took the front case half of the axle disconnect off, still no go. The rear case half (axle disconnect) thats bolted to the oil pan has a clean break all the way around, and I don't see any way to get the broken part out without damaging something else.
None of the bolt bosses are damaged, and I can assemble it then put it on.
Soooo, my plan is to rebuild the disconnect and try some gasket maker on the broken part. Wish me luck.
