Sorry, there's no context and I failed to find your previous posts. Which air pump - the air ride or the SAIS? If it's the air ride, and you're already running around on your axle bumpstops, you already know the ride sucks and you might break things if you hit a bump hard. If it's the SAIS - you can safely run without that forever as long as you read your codes regularly to make sure the SAIS pump code isn't concealing another one that's more serious.
