2008 LT Help with rims
bcoth18
I have the feeling ths has been asked before sorry. I have 18 on my 2008 Trailblazer now but tire choices are limited. Can I go to 17 with out any adapters spacers ECT thanks
Looks like OP has a SWB I6, so 16" wheels should work fine.
SWB V8 and LWB models used the larger brakes as well IIRC, and are limited to 17" and larger wheels.
As for the OP's tire selection, I would highly suggest looking at different sizes instead of different wheels. Stepping down to the 255/55-18 that came standard on my Saab will leave you with many options and a reasonable price.
Sorry forgot to add its 4x4 4.2 6 and yea lots more choices in that size compare to 245 60 18
Do you think a 265/60R18 would fit big fan of Cooper AT3
i too have the 18" option.
tires that came w/ it were 245-60-18
for winter tires i ran 245-65-17 on TB rims ( that was before the lift, spacers and bigger tires)
the 17's are only 0.03 smaller in OA Diam. than the 18's, so speedo is only off a fraction.
IIRC the max tire diam. you can run is 30.5". after that you need spacers on stock rims.
not w/o spacers and maybe a lift. those are 31.6" diam.
Ok finally found tires i want General Grabbers AT2 in 255 60 18 anyone else have these and if so any problems Thanks
I'd imagine that should fit. Your speedometer will be 1.6% too slow (if it says 60, you're going 61)
They SHOULD fit, 10 10 tires Calculator says "Overall Diameter: 30.51 in" Thats the 265/60R18
Sexyscissors
