I put the tech 2 on it and couldn't find any faults. Everything works as it should. Looked at the wiring diagram in SM and it disappears into a block called IPC for instrument panel cluster with no detail. Since, there is an action direct directly associated with this, I have to assume that I induced the fault when working on the IPC. When I get time, I will take it out again and see if I can't trace the board connections/routes associated with the panel. BTW: I have had this Tahoe since new, has 200k miles, runs and looks like new, and I have never had any major problems with it. I love this era of Tahoes! I had a Bronco for 10 years prior to getting this and there is no comparison in ride, comfort, reliability!
For answers to above. Only replaced the 9 or so incandescent lamps. Did not attempt to replace LED warning indicators. LED bulb replacements work as they should. LEDs were used to replace all backlight lamps as several were burned out. Replaced them once before with incandescent bulbs and they don't seem to last so I just replaced them all with LEDs. I didn't see the wiring diagram above. Much more detailed than what I have. Thanks to all for input. Will let you know what happens. Might be a week or two!
