Bought the 2005 4.2l evnoy used with 85k miles. It ran ok but used oil. Found out #2 cylinder was using the oil. Finally I burned a #2 exhaust valve. I changed the valve. About 5000 miles later, I burned the adjacent exhaust valve. I just change the entire head with a rebuilt one. I have it all back together and running
The problem: #2 is still wet and the plug has dry carbon deposits. I've seen the exhaust blow black smoke for a second upon startup and then it turns to a gray/white and continues even after it warms up. Its not thick but noticable.
What i've done: Changed the head, new plugs, moved around coil packs, swapped the #1 and #2 injector, compression test (200-195) , checked the radiator/intake/exhaust for air while putting 50psi into each cylinder at TDC, inspected/checked the oil level, inspected/checked the water level, cleaned throttle body, changed coolant temp sensor due to codes 495, 128, 526, 125.
I still have the same problem #2 cylinder is still an issue except that now the rpms are out of control, the coolant temp sensor must be bad (it wouln't read over 100 degrees), and now I have a ticking sound. It still smokes and i'm worse off now than I ever have.
Codes: 125, 128, New code 0014 was present after test drive but went away after next start.
Any suggestions? I've read about the computer having to "relearn". I typically disconnect the battery for that reason, but is there anything specific I need to do?
