1988 OBS LS swap wiring
Armstrong4826
10
Fort Worth TX
Hey guys, I have an LS swap project going and I would like to use the original gauges. However, the previous owner had cut the original harness and I am not sure what wires are going where.
What I have so far:
1-single green wire=coolant temp
2-oil pressure=orange and red wires
3-alternator=single brown wire and B+
4-speedometer=twisted pair green and purple
Unknown:
1=single grey wire that goes to cluster pin adjacent to coolant temp pin(see images)
2=tachometer…diagrams show a white wire but I can’t find the coil wires at all.
8,272
You've probably already --Scoured YT Spanking Clean-- of these Videos...but...jik...THESE Videos are Kinda-Kool as a lead in to another *Spot-On* Resources and will give your Readers-Followers a better idea of what you are dealing with:
TJBaker57
3,329
Colorado
If I read the diagram I just posted a link to correctly the two connector cavities you show your red probe in are circuits 31 and 35 (35 has a typo in the drawing calling it 36 at in point).
#31 is a tan wire, oil pressure, in cavity A13.
#35 is a dark green wire, engine temp, in cavity A14.
Armstrong4826
10
Fort Worth TX
Ok, so the 2-wire “oil pressure switch” is not reporting a value to the cluster? The harness in the truck only had 2 wires going to the oil pressure switch, a red that goes to the fuel pump relay and an orange that goes into the cab. Where does the tan wire play into the oil pressure sensing?
Are there really 2 oil pressure devices on the 5.7?
TJBaker57
3,329
Colorado
I cannot say that I know this!
All I have to go on is the diagram I linked to.
Does the IPC connnector seem to match what you see in the truck?
TJBaker57
3,329
Colorado
I will see what I can find in the diagrams.
I remember my 86 Trans Am with the 305 had a fuel pump oil pressure switch.. There was a fuel pump relay connected to the starter that got the pump running during cranking but then dropped out and a oil pressure switch then ran the fuel pump.
EDIT: Research seems to indicate the relay did NOT drop out and the fuel pump oil pressure switch was a backup system in case of relay failure.
TJBaker57
3,329
Colorado
It "looks" like you may have two oil pressure switches/sending units.
A fuel pump oil pressure switch plus a oil pressure sensing unit that reads a pressure.
Armstrong4826
10
Fort Worth TX
2 oil pressure devices haha, I guess that’s where we were in 1988. Not a bad design but it seems strange today. Well I guess I will be bypassing the fuel pump oil pressure switch since I won’t be using the PCM at all. Thanks for the help, I was wrong in my original thinking.
Also, per the diagram does that mean 39 or 250 is for the tach? Both are labeled ignition
Armstrong4826
10
Fort Worth TX
Does your cluster have a tach?
I can't find any reference to a tachometer in the literature.
Well I thought I had a tach in the cluster this whole time and that’s why I was looking for a tack wire, I must have confused the newer OBS cluster with the one out of this truck. I guess that’s not needed after all on the 88. Oopsie, sorry about that
Armstrong4826
10
Fort Worth TX
No worries!! The exercise allowed me to learn how to follow these older wiring diagrams a little :wink:
Well I appreciate the help, I was on another forum and got no help. I was ridiculed for LS swapping an OBS lol.
Anyway I would like to get opinions on the alternator wire. The TBI engine used a smaller maybe 12ga wire from the alt to the bulkhead distribution block, however the LS has a 1 or 2 ga wire going from the alt to the battery.
Should I mirror the LS system since I will need to use an LS alternator, or would the TBI wire be enough to power the limited electrical load on these trucks?
Armstrong4826
10
Fort Worth TX
Well I finally got the gauge sensors installed, I had to do some research on what senders this truck is supposed to have since everything was missing. I went with the SMP-TS76 for coolant temperature and the SMP-PS154 for oil pressure.
Also the required adapters to install these two…
Let’s hope they are correct haha, if not no big deal really. Next up I need to get a starter and battery to see what kind of compression this 5.3 makes….fingers crossed
TruTru1
