1988 OBS LS swap wiring
Armstrong4826
Fort Worth TX
Hey guys, I have an LS swap project going and I would like to use the original gauges. However, the previous owner had cut the original harness and I am not sure what wires are going where.
What I have so far:
1-single green wire=coolant temp
2-oil pressure=orange and red wires
3-alternator=single brown wire and B+
4-speedometer=twisted pair green and purple
Unknown:
1=single grey wire that goes to cluster pin adjacent to coolant temp pin(see images)
2=tachometer…diagrams show a white wire but I can’t find the coil wires at all.
You've probably already --Scoured YT Spanking Clean-- of these Videos...but...jik...THESE Videos are Kinda-Kool as a lead in to another *Spot-On* Resources and will give your Readers-Followers a better idea of what you are dealing with:
If I read the diagram I just posted a link to correctly the two connector cavities you show your red probe in are circuits 31 and 35 (35 has a typo in the drawing calling it 36 at in point).
#31 is a tan wire, oil pressure, in cavity A13.
#35 is a dark green wire, engine temp, in cavity A14.
Ok, so the 2-wire “oil pressure switch” is not reporting a value to the cluster? The harness in the truck only had 2 wires going to the oil pressure switch, a red that goes to the fuel pump relay and an orange that goes into the cab. Where does the tan wire play into the oil pressure sensing?
Are there really 2 oil pressure devices on the 5.7?
I cannot say that I know this!
All I have to go on is the diagram I linked to.
Does the IPC connnector seem to match what you see in the truck?
I will see what I can find in the diagrams.
I remember my 86 Trans Am with the 305 had a fuel pump oil pressure switch.. There was a fuel pump relay connected to the starter that got the pump running during cranking but then dropped out and a oil pressure switch then ran the fuel pump.
EDIT: Research seems to indicate the relay did NOT drop out and the fuel pump oil pressure switch was a backup system in case of relay failure.
It "looks" like you may have two oil pressure switches/sending units.
A fuel pump oil pressure switch plus a oil pressure sensing unit that reads a pressure.
2 oil pressure devices haha, I guess that’s where we were in 1988. Not a bad design but it seems strange today. Well I guess I will be bypassing the fuel pump oil pressure switch since I won’t be using the PCM at all. Thanks for the help, I was wrong in my original thinking.
Also, per the diagram does that mean 39 or 250 is for the tach? Both are labeled ignition
Does your cluster have a tach?
I can't find any reference to a tachometer in the literature.
Well I thought I had a tach in the cluster this whole time and that’s why I was looking for a tack wire, I must have confused the newer OBS cluster with the one out of this truck. I guess that’s not needed after all on the 88. Oopsie, sorry about that
No worries!! The exercise allowed me to learn how to follow these older wiring diagrams a little :wink:
Well I appreciate the help, I was on another forum and got no help. I was ridiculed for LS swapping an OBS lol.
Anyway I would like to get opinions on the alternator wire. The TBI engine used a smaller maybe 12ga wire from the alt to the bulkhead distribution block, however the LS has a 1 or 2 ga wire going from the alt to the battery.
Should I mirror the LS system since I will need to use an LS alternator, or would the TBI wire be enough to power the limited electrical load on these trucks?
Well I finally got the gauge sensors installed, I had to do some research on what senders this truck is supposed to have since everything was missing. I went with the SMP-TS76 for coolant temperature and the SMP-PS154 for oil pressure.
Also the required adapters to install these two…
Let’s hope they are correct haha, if not no big deal really. Next up I need to get a starter and battery to see what kind of compression this 5.3 makes….fingers crossed
ptully
