06 with push button TC case. Has been "switching" between modes occasionally and has recently gone into 4wd and will not disengage. Suspecting TC control module under the drivers side dash as most likely culprit. Anyone else concur?
Yes, it has been switching between mode without any push of the button. And there have been instances where it would switch out of a mode that I put it in and I would have to switch it back to that repeatedly. It was suggested to me to check wiring harness at the transfer case four signs of debris or water damage.Clarify?? Does this mean it has been changing modes without the buttons being pushed?
Personally I will always suspect wiring faults or terminal faults in harness connectors before suspecting solid state components.
It would not surprise me if say 80% or more of components replaced had nothing wrong with them and it was the harness connector terminals that were the real problem.
Are you getting a service 4x4 light?
Yes I am.Are you getting a service 4x4 light?
So this would tell us there is a detected fault in the system. Again, maybe @TJBaker57 can provide some instructions on how to scan for TCCM codes. Do you have a Bluetooth OBD adapter? if not, the Veepeak from Amazon is @TJBaker57 's favourite and he can guide you on how to use it to scan with it.Yes I am.
Very interesting. Thank you for running it. THe only thing I didn't mention because I didn't think it would matter is that it is an 8.1L truck. Will look through this during lunch.Last Images...
View attachment 116092View attachment 116093View attachment 116094View attachment 116095View attachment 116096View attachment 116097View attachment 116098View attachment 116099View attachment 116100View attachment 116101View attachment 116102View attachment 116103View attachment 116104View attachment 116105View attachment 116106View attachment 116107View attachment 116108View attachment 116109View attachment 116110
Hope it Helps...
