NEED HELP 03 4.2 led conversion no high
TheLureWasher
8
CT
Just did my Led conversion on my 03 EXT. Headlights, tail lights, interior, load resistors. Problem is when the head lights and you try to put the high beams on the low beams go off and no high beams. Checked relay at 43 and fuse 14 both good. Any ideas?
10,687
You can confirm power at the high beam relay and fuses, when engaged? What happens if you put the stock bulbs back in?
4,025
Sounds light a problem with the high beams, just don't know what yet.
When you hit the high beams, the lows, from factory, will turn off. Unless, of course, you've done the quad highbeam mod, which keeps the lows on when you hit the highs.
Adungyyy
