- Aug 22, 2014
- 42
I wondered where all the knowledgeable folks had went from TV. I was pointed this direction. See roadie here.
First off I lost my dash cluster gauges.
Came back from in from golf got in the envoy started it up and no gauges came on at all . All 6 just 0 left side plus no total mileage shown in area that shows mileage and trip miles drove etc.
Everything worked perfect till came back in today. Checked 24 fuse and it's good.
Mileage being out too threw me a curve because I cant keep track of mileage driven for gas.
The gear selector area isnt shown either.
How does the ignition effect this in my problem in last 2 post, just in case?
I pulled the cluster and cleaned all the contacts on back etc
May gauges and odometer and shift indicator all came back on for drive to work. When I left today not working again.
Did anyone try cleaning connections to the under hood fuse box? Mine had some green corrosion.
I cleaned all terminals to the fuse box under hood and pulled the 125mega fuse thing to clean it too.
I am only making things worse. Now my 02 envoy wont start after doing all this stuff trying to get my IP working again.
I cleaned all the terminals going into fuse box under hood. I checked fuses and changed them just in case 22 24.
I cleaned the back of IP board etc.
I can hear things click running under hood and inside area but no start.
I'm only making it worse and cant start to even check to see if last fix worked.
Help I am at a loss to figure this out. What about the security system? Think it has crime stopper for remote start.
Tried the remote start. Thinking security stuff. Everything click runs under hood like it is setting start, but no start.
Even the a/c etc all come on just like it is set. Hit brake to turn everything off without key.
Sorry folks for being confusing, I am trying to piece to threads with 2 different problems over last 2-3 days.
Today I hook both side of batt back up after setting over nite. When getting in I noticed entry lights didnt come on.
Then tried to start. It started.
Dash and all 6 gauges still not working, shift indicator nor the odometer or info center area.
Noticed radio come on go off. Lights get bright then dim on radio then dash. 4x4 shift indicator lights all light up then off then up and then off.
So I turn off restart. Turn off restart. Make sure that was good.
So I turn key to on but not try to start. Pull PCM B and PCM I and the 4x4 module for 5-10mins. Turn key of reinstall all fueses and no start again.
Can hear the clicking etc under hood area when trying to start, but not the starter. Sounds like relay etc.
So fellows I am in way over my head on this 02 envoy xl right now.
Any leads on what may be going on?
