2012 XL Denali, one night I went to turn on my overhead map light, I pressed the light/switch and the light did not come on but it dimmed my instrument cluster lights. Press again still off but IC lights returned to normal.
This happens when trying to turn on any overhead map light, including 2nd row... but with the doors open, all the map lights will turn on as they should. When the lights are on with the doors open, if you press the map light it will turn off.
I replaced the headlight/dome light switch but same issue. I wouldn't suspe t a bad ground at G200/G201 as the lights do work with the doors open
Also, this is a web pic, but you can see how all the steering wheel buttons illuminate a light blue/green, now I only have the two center inside lights illuminate, cruise control in red circle and the right side is the phone button...both inside middle buttons..any help is greatly appreciated.
