"...Anything Else....?"
Yes. Just a suggestion that after you pull the original transmission and before you install the new one...and while you have easier access to the Transmission Cooler "IN --> OUT" Metal feed lines... You should Reverse Flush it while you can still get to it. You might get your hands on something like this modified thing (available for around $30-$45 on eBay-- sold as an "AC Flush Kit") in the photos below (...of course without all of the "Jarvik Heart Pump" apparatus I used here on my first design try at building "The FrankInjector Machine" for cleaning EFIs)... and use some S/S Hose Clamps and two decent lengths of 3/8" Fuel Line to attach the Output of the Aluminum Cylinder filled with Transmission Flush to the OUTFLOW LEADING TO THE -> TRANSMISSION Line ( use about 6 bottles in a row) and then attach the other length of 3/8" Hose to the RETURN FLOW <--- THE TRANSMISSION Line to drain away the old fluid.
THIS is an even more convenient design (stands-rests on its end) on ebay:
http://www.ebay.com/itm/R134-R12-R2...914445?hash=item3abf7f9c0d:g:-X4AAOSwvg9XUk3y
Get a 5 Gallon Bucket with a lid and drill two holes in it... One for the junk fluid to enter the lid /bucket via the 3/8" Hose fitted and fed into another length of Clear Acrylic or Clear PVC Hose so you can actually SEE what the Hell is coming out of the Cooler as initially a Black Stream that will progressively get cleaner and clearer; turning into a sort of transparent Orange Colour when the flush portion of this job is complete. Drill out the second hole in the corner of the Plastic Lid of your Catch Bucket to let out all of the in coming displaced pressurized air... Otherwise... the lid will pop off and scare the Hell out of you!
Your Shop Air Compressor will serve nicely to act as the force needed to drive the Flushing Fluid out of the Aluminum Cylinder...BACKWARDS through the lines and then 'OUT THE IN--->' Line and into the Catch Bucket. Start out by VERY SLOWLY metering in the air into the cylinder... and listen very carefully as the flushing fluid travels backwards.... rumbles and sputters and burps as it meets an awful obstruction deep inside the cooler itself... the pressure should be built up GRADUALLY... so you don't over-pressurize the fluid and risk damaging the lines and innards of the Cooler while trying to push out all of the "Black Mung" that has collected inside along with tiny pieces of crap from the Old Transmission to plug the damned thing up.
Finally... it will let go explosively and then a Black Stream of Old Fluid and Crap will pass through with relaxed force inside of your Catch Bucket ...which will jump around from its arriving fluid under pressure. Put a weight on the bucket before you begin and Duct Tape the Acrylic Hose onto-into the lid... or it will eject itself and spray disgusting Old Tranny Fluid all over the place.
"Wash...Rinse...Repeat" until the contents of all six (6) of the Orange Coloured Transmission Flushing Fluid containers streams into the Catch Bucket and then stop after the Aluminum Cylinder is empty. Next... fill the cylinder up with Fresh OEM Dexron Transmission Fluid... and flush out the Transmission Flush until nothing but Pure, Red, Clean Transparent, Translucent Automatic Transmission fluid is exiting into the Catch Bucket. You should stop before the Aluminum Cylinder completely empties out to avoid having any air in the fluid stream. After the initial "Mung Plug" passes into the Catch Bucket... you can of course increase the air pressure to around 15-20 PSI... just to have enough pressure available to force out the remaining Flush.
https://en.wikipedia.org/wiki/DEXRON
Now cap both of the Metal Lines in readiness for their insertion into the New Transmission... (I recommend that you get some Brand New Line Spring Clips so that when the lines slide in and "Snap-In" they won't pop back out). And so... from this point on... once the replacement transmission is installed... none of the Damaging Metal and Disc Pack Contamination will "poison" the new one. No doubt, you will wind up disposing of this disgusting waste fluid in a responsible manner... but NOT before you have a chance to run a Neodymium Magnet on a string around the bottom of the bucket to see if anything "ferrous" was left behind.
Remember that when you are putting in the New A/T Fluid into the Fill Port NOT to use the entire recommended amount of fluid usually necessary as when starting with an un-primed Transmission Cooler and Lines. Fill it with about two less quarts so later on after the engine and transmission warm up and you check for leaks using a big piece of cardboard under the engine/trans area... you can take a short, local Test Drive and then "inch up" onto the proper filling level when you get back in your driveway and check the "Level...on Level Ground" Don't forget to do one, last "Leak Look" using the cardboard technique ...so if the Transmission leaks after you get a good nights sleep... you will be able to "spot" the problems in the morning!
-=Hope This Helps=-
