- Feb 26, 2013
- 23
Sorry sorry if this is covered on another post already...I can't find anything helpful...just hit and miss ideas...
Anyways my front differential appears to be leaking pretty bad...and it does the whole binding/crow hop thing...so I took it to my mechanic..brought my 4 quarts of Mobil 1 75w-90 synthetic....well he changed out the rear differential.. but when he got to the front he said it appears that I have a pinion seal burst or leaking..whatever. SO anyways he said he can't do anything to it also saying the front end takes a different type of gear oil?? I say BS on that, right??? (I own a Haynes Repair Manual) Front and rear same fluids, just different amounts..anyways he referred me to a local transmission shop to to repair it..
The thing I need to know is what can I do in the meantime before I'm able to take it in on Monday or Tuesday?? Can I fill up the front differential with my 75w-90 synthetic???
Also has Anyone else have the job done?? What did it cost ya?? Because if this is crazy expensive and doesn't fix my binding/Crow hop... I'm about to trade the junky thing in....my mechanic also measured around my tire saying how a couple of them have threadwear off within a fraction of an inch????? Really? So he said maybe new tires to fix crowhop? Really??? I've owned this thing for 1 year and have stuck tons of money in it...
I have put a new fan clutch in, replaced leaking fuel filter, bought new air springs for it (didn't fix problem) bought a new coil spring/shock kit, then awd wasn't working, changed out transfer case fluid, still nothing so I bought a new transfer case motor, (works better in snow, but still seams hit and miss, months later I changed out the transfer case fluid again...still binding..then I find out about all this leaking in front differential....
Any help any help?? Suggestions?? I don't want my truck to get destroyed, don't wanna keep sticking huge money into it...
