Whistling noise above idle
de3jr88
45
Airdrie, Alberta, Canada
Greetings. I have not posted in a long while, but I am looking for some expert technical opinions. 2003 Envoy SLT I6 4x4 4.10 rear end. This was my wifes daily driver for nearly 10 years but is now mine. I had noticed about a year ago that there is a low 'whistling noise' under throttle or when cruising. Cant hear it when windows up or sunroof closed. When windows down or sunroof open you can hear it. When rolling up to stop signs or lights, just before engine drops to idle, it goes away. Does not change tone under acceleration, but is louder during gear changes. Is no different with AC or heater on. I can hear it more from passenger side, but parked cars or roadside obstructions are closer and sound rebounds faster. Now that I drive it every day, I notice it more. Have not noticed any performance difference, or fuel economy.
I dont think it is a pully or a moving part on the engine due to the sound not changing in tone under throttle. Brakes are good, bearings are good.
Any thoughts?
Capote
24,227
Atlanta, GA
Is it a whistling like a vacuum leak possibly? If so, have you checked for any vacuum leaks?
de3jr88
45
It could be, that is more what it sounds like. Its not a window or door seal for sure. I have checked hoses under the hood and they appear ok. Are there vacuum lines under the frame?
Capote
24,227
Atlanta, GA
There's an Secondary Air Injection Pump under the frame on the drivers side. A lot of times these can crack and corrode.
Capote
24,227
Atlanta, GA
No problem, if anything have someone give the rig some gas as you investigate around the engine bay and underneath.
Wooluf1952
2,663
Milwaukee, Wisconsin
The 2003 doesn't have the SAI. That started in the 2004, IIRC.
Capote
24,227
Atlanta, GA
Hmm is that so? One other difference learned now between '02-'03's vs '04 and up.
de3jr88
45
Nope no codes, no CEL. There is a box of some sort with hoses in and out mounted on the frame under the driver seat area, just ahead of the fuel filter. I thought that was the secondary air injector?
Capote
24,227
Atlanta, GA
That's it
jesussaves
