Whining noise, slow acceleration, MPG's getting worse. What to do next?
POW
38
So I have the whining noise going on under the hood & the cars acceleration seems to be very slow lately. I noticed MPGs have dropped as well. Mixed (in Houston traffic) I should be averaging around 15ish & highway 17-18. This already isn't very good but last couple fill ups averaged around 13.5-14.
I am assuming & going to start with changing the idler pulley to address the whining noise. Can anyone link me to the part I need to order?
Would this also impact my acceleration and/or mpgs? What else should I do right now? 02 sensor?
Car currently sits at about 122K miles.
Here is everything that has been done:
New tires at 95K, rotated every 5K since.
K&N air filter at 99K (has not been cleaned since)
New water pump, thermostat/CTS, coolant & transmission flush, serpentine belt, & radiator at 102K miles
New front right wheel bearing at 103K
Spark plugs replaced at 103K
Throttle body cleaned at 103K
New battery (duralast gold) at 120K
I am also due for my next oil change (mobil 1 synthetic) & will be doing that very soon.
I know the biggest issue is I have not done the transfer case fluid or the differential fluids!!!!! I don't ever use the 4wd but yes I know getting these fluids done are very important & a top priority. I have the transfer case fluid sitting at my house just need to do it!
What else should I do or think about doing? I have no codes or lights showing up & other than the recent whining noise & acceleration the truck has been running smoothly & in good shape. Just want to be as proactive as I can in keeping it that way.
  • Transfer case fluid
  • differential fluids
  • idler pulley
  • 02 sensor?
  • clean air filter
  • oil change/filter
  • Oil pressure switch/sensor (had this issue once, seems to be bad sensor, have it in the garage just need to do it)
Can anyone link me to the correct 02 sensor & idler pulley to order? I prefer to order through amazon if available.
Thanks for the help. You guys have always been my go to when I have any issues/questions and always lead me in the right direction.
Robbabob
1,096
What temperature do you run at? The needle should be just below vertical when warmed up ~10 minutes of driving.
If it's running low, even without a CEL alarm, the truck will run rich and clog the cat, THEN your mileage will drop.
Good luck!
Reactions: Mike w
POW
38
Mike, thanks I am going to order those right now.
Rob, I believe my temp has been right at the 210 mark or around there. I haven't noticed it fluctuating and I generally keep a close eye on my dash/gauges now.
Thanks to both for the replies!
There are lots of things that could affect mileage. Look at this thread for lots of things to check.
POW
38
Mike w said:
Hey Mike, or anyone else,
Are you sure the one you linked above is the upstream?
I think this one is the upstream:
http://www.amazon.com/ACDelco-213-1698-Original-Equipment-Heated/dp/B000NW4PJC/ref=pd_sim_263_2?ie=UTF8&refRID=170S0JB1TFC0B2TB5XH6
I believe the one Mike posted is the downstream but can someone please confirm before I order them.
Also, should I order & replace both? Or only the upstream?
Thanks,
Alex
The one you posted is the upstream. I cross referenced with RockAuto and for that number says UPSTREAM IN MANIFOLD.
POW
38
Thanks, Moose.
If I am going to change one, is it best to change the upstream first? Or should I do both?
The downstream one, unless it actually fails, you can leave alone. All it does is report if the cat is working and throws a code if it's below a certain threshold. Does nothing for fuel mixture.
Mike w
287
Thanks,
Alex
Sorry Alex that is correct i copied the wrong link, i had multiple tabs up. Please report if it improved MPG
POW
38
Mike w said:
Hey guys,
I ended up ordering this part & finally got around to putting it in last night. As soon as I fired it up the whining noise caused by the bad bearings was gone but there was a screeching sound like the pulley wasn't a good fit. I used the same washer/dust shield & greased it up good before I put it back in..
At first we thought maybe we had it too tight so we loosened it a turn & the noise was better but still didn't sound right & seemed like the belt was getting hotter than normal.
We took out the AC Delco pulley & compared it to the OEM & the ACDelco has a raised rim around the bearings inside the pulley where the OEM did not, it was flush. We believe that is the culprit & that the ACDelco is not the correct fit. Can anyone confirm?
We ended up putting the OEM back in (still have the whining noise) & I am going to pick up a new one at Autozone.
Anyone recommend the best one to use?
Inert_Static
249
POW said:
Hey guys,
I just replaced mine last week. Some of the pulleys had exposed bearings and I did not trust that design. I got the sealed one from O'Reilly's.
http://www.oreillyauto.com/site/c/detail/GATE/36227/03307.oap?year=2008&make=GMC&model=Envoy&vi=1441132&ck=Search_03307_1441132_-1&pt=03307&ppt=C0328
and it worked like a champ.
I used an aftermarket one and I couldn't reuse the dust shield. Works fine otherwise and the shield is really useless.
POW
38
I just swapped out the ACDelco with a Duralast from Autozone & it sounds brand new. Seems to have helped with power as well but maybe that is just a mental thing as I am not hearing this awful whine as I hit the gas.
Thanks, y'all.
moscoreli
