Wheel spacer question.
ajallen14
68
Ok so this is something that's been on My mind for a while. As far as wheel spacers go I know there are 6x6 and 6x6.5. I was wondering what are those measurements exactly, and my envoy has the 18 in. own rims, so would the 6x6 work? Thanks!
14,950
There are 6X5 spacers that will keep the same as our OEM pattern or the 6X5.5 adapters that will convert you to the more common 5.5" lug pattern.
What are you wanting to do?
ajallen14
68
Yeah I meant 6x5. Well I'm at school right now which is about a 3 1/2 hour drive from home, and I'm gonna get a 1.5 in. level with spacers and 30s eventually, but I don't wanna have to drive home with 30 in. A/Ts. So I want to have a 2 sets of wheels (my stock rim/tire + 30s & A/Ts) but I wanted to leave the spacers on, but I guess I'll have to take the spacers off each time too?
14,950
You don't need wheel spacers for anything under 30.6" tires. For the most part you don't even need a lift to run 30.6" tires.
ajallen14
68
Oh alright. I just wanna level it out though to give it a more aggressive stance. I won't be putting anything on the rear suspension.
14,950
I think you are over complicating what you are wanting to do. If you want to level it and put ATs on there to make it look more aggressive then just run it that way and get a tune to compensate for the larger tires. If you are so worried about gas mileage with the mods then leave it stock and don't do anything to it. Everything that you will do to make it more off-road worthy will come with a price and if you aren't willing to pay that price then you are better off leaving your vehicle the way it is. Even adding the leveling kit will change the dynamics...
ajallen14 said:
...to give it a more aggressive stance....
So this is like a half-a-lift, meant for appearance only? :confused:
Recommend shaving your head, growing a nicely trimmed goatee, and practice scowling like this guy. It won't affect your mileage the way everything else will.
ajallen14
68
Guys -_- I do want to do some light off-roading. I'm running a 2wd/3.42s so I'm not gonna go all out on a 3 in. lift.
blazinlow89
2,088
I have been running a set of 245/75/16 General AT2's which was 30.5" tall, this was stock height no spacers. My gas mileage dropped significantly after the tires had been installed roughly 10.5-11mpg. I also recently discovered an issue that I created, however I fixed the issues and have been seeing roughly 14-14.5 City, about 2 mpg less than before the tires, I have not done any highway driving in the truck since the changes but I will add the numbers to one of my threads later.
While the wheel spacers are not required, they do push the wheels out more giving the truck a more aggressive look. I have pictures posted in the "What did you do to your GMT today" thread. The spacers also allow you to run tires larger than 30.5", however having the 3.42 gears (what I have as well), it is not recommended to go over 32" tires. As it has been stated the adapters will change your lug pattern to the more common 6x5.5 (just about every other 6 lug vehicle uses this pattern). It greatly expands your wheel options.
Honestly if you are going to throw in a leveling kit for the front (I believe Marks .5" upper strut spacer would level most of our trucks), you might as well get the 2.5" kit. It will level your truck as well as give it a bit more height. Its not a huge lift, but enough to know its there.
onlyatauction
