What size is my sway bar?
Blackstar
90
Hey Guys. This might be a stupid question but I don't know what size the front sway bar (stabilizer) is. I was going to order a few parts from Rock Auto, including a rear sway bar link and an oil pressure sending switch. They list several bushing sets for an '02 Envoy. Is there a way to tell besides climbing under the truck with a caliper? My '02 is an SLT.
Thanks
Glenn
IIRC, the EXT/XL use the bigger bars. Only way to be sure, you guessed it, is to measure it.
littleblazer
9,265
If you don't want to get that into it, wrap a string around the bar measure the length and divide by pi. You'll get the diameter from that. Well that's what it did. I had the bigger bar iirc.
That way you can turn the wheel hard and do it from the well.
Matt
4,025
Get wrenches about the same size...whatever fits snugly is the right size.
AzTruckGuy
501
scottsdale, az
Take off the Swaybar bushings in the front and they should be marked if you have the 44mm or 46mm swaybars....I made the mistake of ordering Moogs that where 46MM and I had to re-order the 44mm, felt way tighter after I put them on
Blackstar
90
Thanks for the replies. just getting a chance to get back at this after OT at work past few weeks. Going to measure now.
Mynamesjeff
