Hi I have a 04 Buick Rainier. 175k and am trying to get a list together of things i should replace. to enusre a long buick life.
Some history. just bought the car this past feb with 161k. Had a cracked exhaust manifold wich dealer fixed but in return snapped a bolt in the head and refused to fix. (No know issues with this at this time)
ive changed oil over to synthetic mobil 1 change it every 3k.
in april or may i drained and filled transmission, Front diff, and rear diff and more recently drained and filled transfer case fluid.
New ceramic brakes and drilled and slotted rotors a month after i purchsed so probably have around 10k on them.
Tires were new when i bought truck they slapped new ones on before i bought it.
K&n Air filter wich i am thinking of replacing with different. Any suggestions??
Just replaced thermostat (Horrid thermostat) on thanksgiving morning turned into night.
Spark plugs replaced same time i did brakes.
So what should i replace? Is it a good idea to kinda just go through and replace every sensor i can find. or one of those deals where if its not broken dont fix it?
no idea previous maintenence records. truck runs a little rough but goes ok. Never had a check engine light unless i somehow induced it.
I just feel it has 175k on it preventive maintenece sounds good to me. plan to start these updates/repairs beginning of next year.
i currently avg like 14-16 mpg that was with bad thermostat running at 175-185 degrees.. may improve now its changed.
well any sugesstions would be welcome... not sure how many miles ill get out of her but im going for the max...
