What Shock Is best to use?
snowyredenvoy
52
Ok, So I should be getting marks 3" Lift within a couple weeks and going to put some Z71's on. What shock could accomidate this Lift? Approximatly 3.5 inches? maybe a lil more, Dont carry much weight very often... I will look like dork with a 3.5 inch lift in back and a 4 inch lift with 86's up front with stock tires... Untill I get bigger tires. lol $$$:frown:
snowyredenvoy
52
I beleive the fox shocks are the way to go...? the 2" lift shocks for the envoy wil work correct? Well worth the money.. But I will be running stock legth shocks for awile with the lift. How bad is the topping out going to be?? thanks
jham
1,334
I might be wrong but someone will correct me, but with Z71's and Marks spacer you will have to run the longer shocks
snowyredenvoy
52
I am going to wait till I get the longer shocks to put the Z71's on.So i will only be running the 3in lift with the Stock length. Sorry should have mentioned above..
jham
1,334
as far as i know you will be good with stock shocks in the rear then. on a side are you getting the new fronts when you put the lift on?? If not and this it just :twocents: I would wait to put the lift in so you don't have to get it aligned twice to help ya save some money. and be sure to look up the UCA flip too
snowyredenvoy
52
Yep, Putting bilsteins up there. And Yes. I will be doing the uca flip. Thanks
Wyle
I'm installing a 2" front/rear lift later. Does a UCA flip make sense for that setup, or is it only necessary for higher lifts?
ScarabEpic22
728
Im not sure, I have Marks new style 3" front lift and I flipped them because I had the front suspension apart and didnt want to have to pull it apart again to do it.
In the rear of my 02 with 2" spacers and stock springs, my Bilstein HDs did not even fit. DONT TRY TO RUN STOCK LENGTH SHOCKS ON A LIFT! I bought some ProComp ES9000 shocks that are 2" longer than stock and they work really well. Think I paid like $38 + tax each at 4WheelParts (they have a few locations local to me) plus another $4 for some shock boots. Compared to $60-65 for Bilstein HDs, they're a bargain and actually the right length. I used ProComp ES9000 series pt #926500 for my 2" lift and they've been great for ~4k.
It's not required, but it's free, and doesn't hurt. I would only defer it if you're pressed for time when you install the spacers.
snowyredenvoy
52
Great... With that information, Looks like the lift install will be delayed even longer..:frown: I would think with the 2" lift that you should do it While your there just incase you get an allignment. Why not? I dont think it would hurt it would it?
Wyle
Thanks for the replies. Left UCA bushings are shot. Lift work was waiting for new one, which came yesterday. :biggrin:
@ Scrab - got boots for the new rear shocks at local 4WheelParts two days ago. :smile: Thanks for the cautions.
ScarabEpic22
728
:iagree: but honestly it doesnt take that long. Think it took my dad and I about an hour to do both, and half of that was finding a wrench that would work and "assisting" some sheet metal out of the way :rotfl:
In case you get an alignment? No no, you NEED an alignment immediately after installing your lift. I put my TB back on the ground and it immediately went to Firestone to get aligned.
Flipping UCAs is pretty easy, just need a big crescent wrench to break them free (couldnt get a socket in there) and maybe a crowbar to move some sheet metal.
No prob, Id never heard of them until August when I was scouring the 'net looking for a local vendor to source shocks. They'll get my business again, their prices are comparable to online and being able to return stuff to a physical store is nice, if needed.
djthumper
Administrator
Nov 20, 2011
14,950
North Las Vegas
You had never heard of them because you were not into wheeling at the time. Except maybe at the mall. :wink:
ScarabEpic22
728
Ha not even then! The most offroading the 02 had done is some gravel roads for 30ish miles.
Its a mall crawler, I dont advertise it but I lifted it for snow clearance and because I could! :rotfl:
The SS has barely seen gravel roads!:lipsrsealed:
djthumper
Administrator
Nov 20, 2011
14,950
North Las Vegas
But you have stated that you wanted to do some mild wheeling with fishsticks and Wootown. That will definitely be more than the mall crawlers do. And the 30 miles on gravel is more than any mall rated lift would handle. Don't sell yourself too short on that yet kiddo... you might catch the bug yet. There is nothing wrong with enjoying the street runs and fast vehicles and off-road at the same time. :cool:
snowyredenvoy
52
Thanks for the correction, My bad. I guess its a good day when the previous owner leaves all information and options that was originally ordered on the vechical and I see locking differential on there and look into the glove box and spot the g80:wootwoot:
What a good day:biggrin: Alot less work with that found lol, i have about an hour drive on highway back from the place I am going to install the lift from should be ok until I get aligned right?
ScarabEpic22
728
That road was with a completely stock truck, that was back before I could even drive (so 2004/2005).
Im excited to get into some mild stuff with wootown and fishsticks simply to get outdoors more, I used to camp/hike a TON then I went to college and havent had the time in the last 4 years.
But I agree, slammed+big hp for street, lifted+big tires for offroad. Ive got a TB for each right now, just have to snag the 02 from my bro and do my offroading in the summer when he's driving his Jetta.
Sweet, G80 = good thing!
An hour should be ok, be careful as the front will feel really light and floaty on the highway. I likened it to putting a large trailer behind you with a little too much tongue weight so the front end is floaty. Id highly recommend going to a shop asap, last thing you want is to have to turn in an emergency and not be able to.
Wyle
When I replaced the right one 5 months ago, I was thinking "ha, no bending required." Today I learned that the left one ... well, not so simple. About a half inch of "assistance" was needed.
I also had to do some customizing to flip OE UCAs. The top of the ball joint boss is a little thicker than the bottom and doesn't have a chamfer to properly accommodate the ball joint stud when you flip them, so the hole in the arm doesn't line up with the groove in the ball joint stud. Nothing a angle grinder and drill press couldn't overcome.
djthumper
Administrator
Nov 20, 2011
14,950
North Las Vegas
That will help it settle some just be careful as ScarabEpic22 has stated. I was told to come back after about 1000 miles when it settled as I only drove less than 2 miles to get mine done. So if you have someplace that will do lifetime alignment deals that would be your best bet.
snowyredenvoy
52
I wish that somebody would do a write up???:poke:
Regulator
2,496
Me007gold said:
Bilstein HD's up front, then white body shocks in the rear (BDS, Skyjacker, ect.......)
:iagree:
snowyredenvoy
52
The UCA flip
snowyredenvoy
52
Thank you, I think I need to join the ORTB.lol Just trying to gather all the information. Thanks, sorry Newbie....
stormsurge
386
I just installed marks 2.5 lift and stock shocks fit fine. They where. monroe's.
Fiddlermatt
