What is this sensor for??
WeaponX
212
Pittston, PA
And what does it monitor?
Ever since I put those new injectors in I’m still trying to hunt down why I keep getting codes for running to lean & idoling at almost 1k & was wondering what this sensor monitors just Incase this has something to do with it. Thanks41309940-8C84-4A3F-A15C-68353380627F.jpeg
Mounce
13,667
Tuscaloosa, AL
IAT (intake air temp) monitors the air temp going into the motor. If yours is pre MAF then it plays a part in the computers tuning. Computer will watch MAP and IAT to adjust. Think it's called speed density tuning?
seanpooh
461
Your idling rpm jumps to ~1K because of the lean DTC set. I've seen that you've done lots of work to your truck so far. Double check your torque at the intake manifold. Spray brake/throttle body cleaner around the booster & intake. The document gets more technical.
  • p0171.pdf
evenson1
