Water Pump
Machoman
123
I think my water pump may be leaking. I can't tell if the pump is leaking (not much room to see). I have a leak that running down the frame to the drivers side. The fluid does taste like coolant. I was able to see the lower radiator hose. It was dry.
Does this sound like where the fluid would leak?
Which engine?
7,746
Likely happening around the GM OEM Water Pump Metal Gasket, the Lower Water Pump Bolt-On Flange (Circled in Red), the WP Shaft-To-Bearing Seal, or around the Rubber "O" Ring Inner-Flange Seal of the Thermostat Housing (Circled in Blue):
33chevyrod
