- Aug 2, 2014
- 90
Got an weird problem that I noticed a month or so ago. '02 Envoy SLT. Had -20C temps for about a week and had to start my truck after hooking the charger up because all I got was about 3 cranks of the engine then just a click.
So, I installed another battery, 6 months old but with top posts, I bought a set of adaptor cables and this worked good for about 5 days then was running dead overnight at -5C temp. So I fully charged my original battery (Everready 5 years old) and the truck has been starting great ever since... with one exception. On a cold morning or night I start the truck and the volt meter sits at the mark between 9 and 14 volts, lights are dim and DIC is not running through it's checks. After about 8 to 10 seconds the volt meter goes directly to just over 14V and the lights brighten and the DIC tells me to check my brakes (another issue. I have pulled the fuse for ABS because of sensor problems).
It only does this in below freezing weather (or so I've noticed) and after the pause everything is normal... Any ideas on what to look for?
Thank you
Glenn
Thank you
Glenn
