Lately I have been getting a vibration when I turn the front wheels to the right. It only does it if I'm not moving or barely moving. It's been progressively getting worse as time goes on.
The upper ball joint on the passenger side does have some play in it. And its really easy to move around. Driver side upper ball joint seems OK.
Could the upper ball joint on the passenger side be the cause of the vibration?
Any tips on replacing the upper ball joint? I've been reading up on the presses and watching videos. Seem more time consuming than difficult. I've never replaced ball joints before. But it doesn't look too difficult.
Is one brand of upper ball joints better/preferred over the others? Probably going with rockauto again for parts.
Thank you in advance for any help.
