- Dec 6, 2011
- 62
I live in central Florida which can get quite hot in the summer, however I tracked my temp several times driving today.
With ambient temp of ~80F:
With ac on runs consistently at 212, highest reading was 216 momentarily.
With heat on ran consistently at 207 to 208.
It isn't hot enough outside to justify running over 210 even if it is slight. Truck is well caught up on maintenance and the radiator was supposedly flushed at approximately 60K along with replacing a a radiator hose. Everything runs pretty much as it should otherwise. The only variable I can think of is that I topped off the refrigerant recently, I don't think I overfilled it but I was towards the top end of the "green zone" on the attached gauge. Should be within spec +/- 5psi. I believe the thermostat was replaced at 60K as well. I Currently have 80K miles on the vehicle. Should I just pretend I don't see the needle creeping to the right, it is only 6 degrees and about 3 percent?
In Response:
No codes or CEL
I visually inspected the fan and I can't see any dings, or chipped pieces but I haven't gone further than that. I suppose it could always be the good old fan clutch, but I do not have the typical accompanying jet engine sound.
According to my maintenance records the fan clutch was replaced at 37K at the dealership. Thermostat was replaced at 60K.
In Response:
No codes or CEL
