Upper Ball Joint failure
miron
56
Just took my '06 Envoy/135k in for it's annual PA Safety inspection. It failed due to upper ball joints needing replacement. Now I consider myself fairly good at repairs as I've done several to my truck. The question is, should I do the ball joints myself or take it to a shop. And if taken to a shop, what is the likely cost
floridafitz
151
Winter Springs FL
Had mine done by a mechanic, upper and lower, for $200 btu that was an unusually good price. Stealership could easily be a 4 hour rated job so depends on the hourly rate plus shop supplies, etc. FWIW, I was told this is a difficult job. Think about replacing the upper control arms while you're in there since the bushings are probably shot. Good pricing on RockAuto.
Closing this duplicate thread because you're getting replies in the other one as well.
fhenninger
